Hi … have removed the grill door of “New World MX6” to replace a spring.
The top trim/handle is removed but not sure of next step. Looks like each corner has a clip but don’t want to continue without advice.
Solved … I removed all 4 corner clips by inserting thin metal bar into gap at edge of door to contact bottom of each clip. Light tapping pushed clips out. Might not be the correct way … but it worked. The door then came apart to reveal broken spring.
The springs are slightly different for left and right so be sure to order correct one.
