newworld gg720 oven cooling fan
Home Forums Public Support Forums Help And Support Cooker And Oven Forum newworld gg720 oven cooling fan
  • #64173
    bobeggs
    the cooling fan on this oven fails to start and so overheats and knocks the oven off can someone explain where this fan is located
    cheers
    #356286
    washtronics
    Re: newworld gg720 oven cooling fan
    it will more than likely be the pcb not the fan
    #356287
    wsts
    bobeggs wrote:the cooling fan on this oven fails to start and so overheats and knocks the oven off can someone explain where this fan is located
    cheers
    If this is a gas oven you cannot do this yourself, the fan on this is used for combustion as well as cooling making it a job only for a competent engineer.
