no go w/m aeg
  • #54974
    fids
    hi guys i have an aeg w/m 76810 no lights or electronics when switched on but w/m starts to fill please advise
    #321552
    Re: no go w/m aeg
    Wrong forum again fids…post it in TRADE TECHNICAL
    #321553
    don
    Re: no go w/m aeg
    Moved 🙂
    Don
    #321554
    fids
    not sure what you mean
    #321555
    fids wrote:not sure what you mean
    You are asking ‘technical’ questions but posting them all in the General forum or in the Simple PCB repairs thread instead of Trade Technical forum.
    Have a quick read of each forums description, if you do put it in the wrong place we will always try and move it to the correct one.
    Bear in mind, some people only read certain forums so if you do post it in the wrong place you may miss out on getting an answer. 😉
    fids
    thanks very much
    #321557
    Re: no go w/m aeg
    No problem, if you can post up the full PNC number of this machine then someone may be able to let you have the diagnostics info. 😉
    Re: no go w/m aeg
    I’d guess fids isn’t going to be able to access diagnostics when he’s got no lights or display 🙁 .
    Fids, have you meggered / disconnected individual components to see if there is any change in the machine’s behaviour?
    Have you examined board / boards for visible damage?
    Have you tried squeezing / tightening and wiggling connector blocks?
    I wouldn’t want to encourage any unsafe practices of course, but if you do this with the power on and with a wooden stick you may be able to find a loose contact. 😯
    Mike.
    #321559
    fids
    ok thanks i will try this i always test live but take major care i have checked supply will check board
    #321560
    bigchrisoioi
    sounds like blown boards…will prob need both pcb’s and interlock…BER methinks!!
