No lights on Beko oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum No lights on Beko oven
  • #96711
    Steven Diffey
    I have a Beko oven and have verified that power supply is not the issue, by swapping fuses and seeing that the separate hob (which shares power) still functions.
    I have also tested the resistance on the thermal cut-off and clocked a 0.8, same as baseline (https://photos.app.goo.gl/Zm5gcFWy4satAmPx7).
    Anything else I can do before I write it off?
    Thanks in advance guys.
    #464530
    Specialist01269
    Have you checked the main connection block where the power goes into the oven ?, Problems here are not uncommon on Beko cookers.
    Please make sure that you isolate the power first.
    #464531
    Steven Diffey
    Yeah – looked at that.
    No frazzle or burns and it felt very secure.
    #464532
    check the switch behind the knob look for burnt or damaged contacts
    dave
    #464533
    Specialist01269
    Have you tried inputting your model number on the search bar to see if anyone else has had the problem ?.
    #464534
    Steven Diffey
    Which knob are you referring to Dave?
    Yeah – I’ve had a scourer.
    #464535
    it was the main selector knob I was thinking
    What is the model, saves me stabbing in the dark as we don’t know which cooker we are talking about
    Steven Diffey
    Hi Bob – it’s a Beko oif 22309
    Thanks very much for querying.
    #464537
    live goes in and goes to the clock. it then goes to terminal p3 on the control sw. If it gets there make sure it comes out the other side of the switch when you turn on
    neutral comes in and goes to terminal 4 on the switch. Also make sure it switches to terminal p2 when turned on
