Re: No model number or brand name in my washer
Hi, The engineers on here will most likely confirm but from the picture your machine looks like a Merloni built washer dryer sold by MFI, unfortunately neither the original MFI or Merloni are no longer in Business so i doubt you will find a manual for your machine, there is a previous post just below this one which may help in using your machine, the diplomat APM8702 is also similar.
The dials are from the left wash temperature, dry time and finally wash program, the buttons from the left are aquaplus rinse, half load , no spin and on/off. These machines are normally 5kG wash and 3Kg drying load and the half load has to be selected for the dryer to function, they are a fairly simple machine to use, basically set the right hand dial to the program number required (see front of soap drawer), set left hand dial to wash temperature and leave centre dial set at “0” and press on/off button, to automatically dry set dry time on centre dial, press half load set wash program and press on/off, remember to only wash and dry a 3KG load, These machines also take about 2 hours to perform a 40 degree cotton wash 🙁 . hope this helps
