No Motor movement
  • #82329
    lemop
    Hoover optima OPH616-80 N-3100285409391510
    Found load floating in water, cycle not finished.
    Drain, Rinse = pump out, and water in no problem.
    Anything asking for motor dead stop just sits there.
    Looking around but little confused No display on this optima for codes.
    Different mark1 2 etc?
    Pointers greatfully accepted
    Slange….
    #419541
    Re: No Motor movement
    Motor not working? You best move is to now take a look at the motor. Chances are the carbon brushes on it may need replacing (assuming it is a brush motor mind? I haven’t checked myself) HTH?
    #419542
    lemop
    Thanks Martin, Motor out and no continuity across comm, brushes down to id numbers. Cleaned comm and slots,brush slide and rebuilt, now working.
    New Set brushes ordered to replace these.
    Thanks again
