No power to drum motor
  • #74610
    Anik
    Haier XQG50-1100CTX On test motor runs fine . Plug onto machine wiring loom , no go. No power on loom pins at motor
    #392241
    Specialist01269
    Re: No power to drum motor
    Hi Anik: Does anything else work ? i.e does the Door interlock work, does it take in water etc ?
    #392242
    Anik
    Yep , loads water , pumps out just won’t wash or spin . Replaced bearings 2 months go , brushes OK .
    Mega test on motor OK
    #392243
    Specialist01269
    Hi Anik: Have you looked at the controller ? You may find that you’ve got a gad drive relay or Triac on the board or maybe something as simple as a dry joint.
