no power to fill valve
Home Forums Public Support Forums Help And Support Dishwasher Help Forum no power to fill valve
  • #77067
    monk1
    I have a indesit dis04 dish washer everything seems ok but it wont fill I have checked and there is no voltage at the fill valve. Is it the pcb or is there something in the safety circuit that I am missing ( door switch is ok)
    Any help would be appreciated.
    #400910
    Washdisher
    Re: no power to fill valve
    Check for water in the sump which will activate the anti flood device (polystyrene float with a microswitch above it). This would cause the PCB not to initiate filling.
    Check security of fill valve connectors to PCB. You’ll have to trace the wiring from the valve to the PCB.
    Check for voltage where the fill valve block connector attaches to PCB.
    Check that the machine has drained thoroughly. If not, check the outlet for blockages and the drain pump for obstructions, continuity and voltage.
    That should keep you busy for minute or two 😉
    #400911
    Moved to correct forum.
    We do not advise doing any live testing, it is not neccessary.
    #400912
    Washdisher
    point taken, sorry
