no spin on hoover WDM120
  • #13525
    PGS
    Hi been to the above today, when put on rinse it fills and distributed, then when timer clicks onto spin theres only pump action. I hung a motor on which proved to be the same. Thanks in advance Paul.
    #155340
    Bryan
    Re: no spin on hoover WDM120
    Inspection of module would be the obvious next step. Look out for dry joints and cracked/blown solder connection at relay contacts on PCB 😉
    Bryan
    #155341
    PGS
    Cheers Brian I looked for the obvious on board, ill order new board and give it a go , il let you know how i get on Paul.
    #155342
    PGS
    Bri new module fitted today m/c now 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}cheers Paul
