No temperature markings on Indesit built in oven FIDM20 MK2
Home Forums Public Support Forums Help And Support Cooker And Oven Forum No temperature markings on Indesit built in oven FIDM20 MK2
  • #77626
    Pepe2509
    Hi!
    I have recently moved into a property with a built in indesit oven FIDM20 MK2. Unfortunately the markings to set the temperatures have been rubbed off. The oven is otherwise in good working order.
    Is there a part I can purchase such as a transfer to re-mark the temperatures, or a new control panel with the markings on?
    I appreciate your advice and time in replying.
    Kind Regards
    #402825
    Re: No temperature markings on Indesit built in oven FIDM20
    It would be a new control panel I’m afraid.
    If you drop Dave a line on spares@ukwhitegoods.co.uk he can check if it’s available but it will mean stripping down that section of the oven to replace it.
    keepitsimple
    If it were me, I’d get a cheap oven thermometer and try it at 3 or 4 different heat levels – you could probably work out a scale from that ? If that works, with a bit of imagination you could probably get some smart permanent way of marking it up.
    #402827
    jjulieengland
    Hi I have had the same problem, I ordered the oven decals online, just fitted them, looks like a new oven.I searched ovenlettering.
    Hope that helps
    Julie
    #402828
    mark adam
    I bought a set from ovenlettering
