Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › no water into integrated diplomat 8252
- This topic has 6 replies, 2 voices, and was last updated 18 years, 8 months ago by
Sarks.
August 1, 2007 at 7:59 pm #29454
Sarks
ParticipantHelp… got an error E1, then it seems there is no water coming into the machine. It seems to drain o.k. as i picked up a few tips from here. Thanks guys, but now no water seems to come through. Someone please help 🙁 Model is Diplomat ADP 8252
August 1, 2007 at 8:47 pm #223137clivejameson
ParticipantRe: no water into integrated diplomat 8252
E1 is ‘water in base’, ie it’s leaking/overfilling.
Tip machine back at 45o with towels around it the drain the base pan then find the leak….plug out of course :zap:
August 1, 2007 at 8:54 pm #223138Sarks
hmmm… brilliant thanks, but this is where it is integrated. Do you think this will also resolve the water not coming into the machine. The E1 is no longer displaying as i powered it on and off a number of times.
August 1, 2007 at 9:00 pm #223139clivejameson
Sarks wrote:hmmm… brilliant thanks, but this is where it is integrated. Do you think this will also resolve the water not coming into the machine. The E1 is no longer displaying as i powered it on and off a number of times.
You can with a bit of patience mop out the base with a sponge via the lower kick panel to save taking it out of the installation but you’ll still need to find the leak…and more importantly fix it which will most likely be impossible in situ.
Powering on and off can reset the pcb so it simply no longer remembers that the fault occurred but it will prolly pick it straight up again when you try to run it 😕
I should add that you must ensure the appliance is fully isolated before doing this!
August 1, 2007 at 9:05 pm #223140Sarks
Thanks mate will give it a shot and yes ensure i unplug it before attempting
August 5, 2007 at 11:24 am #223141Sarks
Well i have given a good clean and drain of water, water started coming in 🙂 , but i’ve found the leak which i believe is coming from the base, where the bottom arm sits, or around where the central plastic filter sits…anymore ideas please
August 5, 2007 at 1:18 pm #223142clivejameson
The only way TBH is to get the machine out of the housing, get the base tray off, run the machine until a leak appears, unplug, tip back and then have a really good look with a torch if necessary. Any leak usually leaves a pretty good trail of water so follow it back to the source and let us know precisely where it emanates 😉
This particular model is made by Smeg which do occasionally get leaks although the sump pan is not a common one.
