Noise levels in dBs please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Noise levels in dBs please
  • #31582
    beep
    Hi, I have decided to replace my leaking Blomberg and am trying to decide between tissue paper (ie £179 and the certain knowledge that I will just replace it in hopefully 3 yrs) or quality ISE or Miele.
    Because my living area is open plan can you tell me the dBs of the ISE and Miele plse.
    #231754
    Re: Noise levels in dBs please
    beep wrote:Because my living area is open plan can you tell me the dBs of the ISE and Miele plse.
    You didn’t specify which models of ISE & Miele?
    The ISE 5 (CI555WH) as a max dB of around 60, so a whole lot quieter than that aged Blomberg of yours that’s for sure!
    Miele don’t generally state the dB levels on any of their washing machines as far as I know? 😉
    #231755
    beep
    Whoops – I was looking at the ISE5 but am shocked by the 60dB. That is noisy given that dBs are exponential. Most of the cheap ones in the shops are under 56dB many around 54dB.
    Hmmm food for thought as the reviews on Miele’s customer service are poor but if the machine works who cares after 10 years Id probably want a change of machine anyway.
    Do any owners have any comments? It will be placed on a concrete floor. My Blomberg is actually quiet during the wash but I can only use the 600 spin because the 1300 sounds like a rocket and bounces around so much it is quite scary.
    #231756
    The ISE 5 is about 56db from memory but I’d have to check it to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure, it’s not 60db.
    The ISE 10 is 54db.
    Both are considered quiet and unintrusive.
    HTH
    Hi Beep,
    I finally snapped and put together this article which will explain why I always advice people that the dbA ratings are a total and utter waste of time IMO.
    HTH
    don
    kwatt wrote:Hi Beep,
    HTH
    :tup:
    Don
