Noisy boiler, not the missus
Home Forums General Trade Forum Noisy boiler, not the missus
  • #23009
    cornwell40
    A bit of an off chance that someone may be an expert on boilers as well.
    When the heating is running we get a noise through the house (intermittently), that sounds like a B52 doing loop da loop above the house. Please help its driving me nuts. Baxi Genesis 80 combi.
    Tony C
    #196771
    Airlock? 😉
    IIRC you’d have to bleed the system off or do some mad plumber trick with the hot tap that I can’t quite recall. 😕
    Dave_Conway
    Re: Noisy boiler, not the missus
    Air in the system would be my guess, try bleeding the rads of air and see what happens 🙂
    #196773
    Dave_Conway
    Oi 😆
    #196774
    gegsy
    OR has some dimwit put some of the radiators the wrong way round upsetting the regulator valve on the radiator, I know this because I have had some dimwit do this 😆
    goosegreen
    Try asking on this site http://tinyurl.com/yxmo6j They are quite helpfull as long as you state that you are not a plumber.
    Goose
    #196776
    B52 eh? My old Potterton does a cross between the Concorde and a single engined Cessna whenever the header tank runs low. (It’s got a sticking cock don’t ya know, I must get up there and replace it before it starts to sound like a B52 😯 )
    Bleedin’ radiators all the time I am….. 🙁
    #196777
    cornwell40
    Cheers for the replies Gents 🙂
    For the first few days I genuinely thought it was a prop plane doing airobatics as we live near a few airfields 😳 . Weird noise!!!
    Tony C
    #196778
    paulpaddison
    exactly like martin said, ball valves allways seam to stick on the expansion tanks on heating systems especialy during the summer months. make shure it aint seized up and see if the tank is empty. also try adding a chemical cleaner to the water to prevent boiler and pump noises traveling through the system. cant remember the name of the stuff i last used on a customers heating system but it does work. helps make the system last longer too
    #196779
    cornwell40
    The pressure guage for the system is faulty I think. Opened the tap for a couple of seconds before Chrimble and the noise has gone.
    #196780
    paulpaddison
    ohh its a combi boiler 😀 sounds like ur diverter valve may be on its way out. ur gonna need a boiler engineer to replace the pressure gauge and check diverter valve you may need the system flushing or simply an adative adding to one of the rads to help clean the system either way dont leave it too long if that valve does go you loose hot water heating may still operate
    #196781
    paulpaddison
    hi has the boiler problem been sorted yet ❓
    #196782
    cornwell40
    Yep thanks, been fine since. 😀
    I think a new boiler will be purchased over the next couple of months though. It looks a little battered from the previous owner 😥
    Tony C
    #196783
    paulpaddison
    reminds me of a flat i just been working on a young couple lived in it previousley and when the lady found her boyfriend was cheating on him she kinda ripped out the toilet and sink smashed every door in the place destroyed plasterboard walls and all sorts 🙁 luckly the chap who moved into the flat after the last lot moved out had moved in after it was renovated 😀 i think the only thing that survived that girls temper was the boiler.
