Noisy Bosch wta2000 tumble dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Noisy Bosch wta2000 tumble dryer
  • #82709
    Dosser
    Hi there. Any advice. I have a very noisy Bosch wta2000 tumble dryer. The 3 rivets at the back seem ok, but there is excessive movement at the front. I can move the drum up and down. Is there a bearing at the front? If so what part do I need. Many thanks.
    Dosser
    #420638
    Re: Noisy Bosch wta2000 tumble dryer
    this dryer is a white knight dryer in disguise
    it depends on what sort of noise you are getting
    ie is it a clunk, scraping , or just noizy.
    in the end you may have to strip it to find out
    various things go. one of the most common is the fan. since this dryer is not bosch built most spares are very cheap
    Dosser
    many thanks Dave. it is a scraping noise very noisy and you can lift the drum front about 1 cm. Dosser
    #420640
    not really worried about the drum they can move i would look at the motor fan common fault
