Noisy candy condensing dryer when warm
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Noisy candy condensing dryer when warm
  • #100662
    Séan Hefford
    Morning,
    I have a Candy grand o vita GVSC9DCG80 when it gets warm starts to squeal for a period then runs as normal. This noise happens on for a time and off for a time only when it’s warm.
    Any help would be appreciated
    #481684
    it will either be the belt tensioner pulleys
    https://shop.ukwhitegoods.co.uk/tumble-dryer-pulley-wheels
    or the pump 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time
    see if you can find out if it only makes it when its pumping water
    Séan Hefford
    Thanks I’ll check tonight
    #481686
    just re read my post and it look like i suggest the pump is more likely and its not. if i had to take a guess pulley would be first
    but whatever it is is a pig to change as access is difficult on these
    Séan Hefford
    I replaced the pump and it’s sorted. Thanks for advise.
    As you said it was a pig to change
