Noisy drum on bosch classixx 1200 express
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Noisy drum on bosch classixx 1200 express
  • #90707
    yellow snow
    I have a relative with a bosch classixx 1200 express and when the machine is spinning it starts to vibrate slightly and it sounds like it’s rubbing on the front right hand side at the bottom. I’ve turned the drum by hand and it sounds like a worn wheel bearing on a car. The filter have been checked at the front but that was clear so would anyone know what other things it could be.
    E-NR WAE24162UK/01
    #445696
    Re: Noisy drum on bosch classixx 1200 express
    Sounds like the bearings are shot.
    yellow snow
    kwatt wrote:Sounds like the bearings are shot.
    K.Thank you for your reply.
    Would you know a definite way to tell if the bearings have gone as I don’t want to order the bearings to find it was something stuck in the drum. Also will I have to buy the bearing kit that comes with a seal or will I get away with buying the cheaper bearing set and not replacing the rubber seal.
    https://shop.ukwhitegoods.co.uk/172686-washing-machine-bearing-kit
    https://shop.ukwhitegoods.co.uk/05ss09-washing-machine-bearing-kit
    #445698
    To check for bearing failure, power disconnected, remove the back panel and release the belt from the main drive pulley. Then from the front spin the inner drum by hand. It should be virtually silent and rotate freely. Any rumbling noise and the bearings are toast for sure. If the inner drum has any lateral (up and down) movement on the drive shaft the bearings are shot and so too often the shaft. If there’s a distinct scraping/metallic noise then it’s not the bearings but something caught between the inner drum and outer tub (bra wires, credit cards, hairgrips etc caught between).
    HTH?
    #445699
    yellow snow
    Martin wrote:To check for bearing failure, power disconnected, remove the back panel and release the belt from the main drive pulley. Then from the front spin the inner drum by hand. It should be virtually silent and rotate freely. Any rumbling noise and the bearings are toast for sure. If the inner drum has any lateral (up and down) movement on the drive shaft the bearings are shot and so too often the shaft. If there’s a distinct scraping/metallic noise then it’s not the bearings but something caught between the inner drum and outer tub (bra wires, credit cards, hairgrips etc caught between).
    HTH?Thank you for your reply.
    I will try what you said as I want to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure it is the bearings as I know someone that had a noisy washing machine so they phoned the warranty company and they sent out an engineer and they said it was the bearings so he ordered the parts but when another engineer came out to fit the bearings he found it was a bra wire and not the bearings.
    I do think it’s the bearing as before I asked how do I make sure it’s the bearings I tried pushing down on the drum but there didn’t seem to be any movement so I tried pushing up and you can feel movement and you can hear a slight knocking noise. I then put my hand on the inside of the drum and moved left and right and it feels rough.
    Would you be able to tell me what kit to buy as I’m put off getting the bosch kit when the bearings have failed when the machine is used once a week..
    #445700
    due to the design of the tub you need a bearing kit that includes a seal and screws to bolt the drum back together. to split drum you have to break the plastic clips and screw the drum back together
    bosch gen kit 172686
    seal kit only no bearings 265964
    if you want parts breakdown go here
    http://www.bosch-home.co.uk/store/spareparts/search
    and put you Enr in
    then go here https://shop.ukwhitegoods.co.uk/ to source spares
    yellow snow
    electrofix wrote:due to the design of the tub you need a bearing kit that includes a seal and screws to bolt the drum back together. to split drum you have to break the plastic clips and screw the drum back together
    and put you Enr in
    DaveThank you for your reply.
