Hi, we’ve recently purchased a AEG dce73110m double oven which has a fan in both the top and bottom ovens. The bottom oven is quiet when on but the fan in the top oven seems excessively noisy. Is this likely to be a faulty fan? Thanks
Hi, thanks for the reply. It doesn’t sound like is catching, it’s more of a rumbling noise so maybe it is out of balance and I’m assuming that means a new fan?
correct
although its more then likley the motor if you swop the fans you will be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain its the motor if the noise stays in the same oven
a lot of oven fans use a left hand thread to take care when you undo the nut. it may be either direction
start the fan and see which way it turns. If its clockwise the nut will probably undo in a clockwise direction
