Noisy Fan Oven
  • #36021
    Jen1981
    Hi all,
    The fan in my oven has started to sound like it is about to take off so the other day I gave it a squirt with some WD40 which has made the noise less but now when I turn the oven on it fills up with smoke!! Should I not have sparyed WD40 in there?? Will I need to call someone out for this??
    Jen
    #249249
    philfish
    Re: Noisy Fan Oven
    sounds like you also sprayed the heating element which fits around the fan and its now burning the wd 40 off the wd 40 will at best only be a temporary repair so i would advise you get someone in to look at your fan
    regards phil
    #249250
    Jen1981
    Re: Noisy Fan Oven
    Ah I see, thanks Phil I will do…. Will I have caused any damage by doing this?
    #249251
    philfish
    Re: Noisy Fan Oven
    I can not say without seeing it but i doubt it very much.
    regards phil
