noisy is70c indesit condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries noisy is70c indesit condenser dryer
  • #32003
    suedehead1
    i am sure this has been asked before probably in its hotpoint disguise but i will ask again so please bear with me.
    i called out to this machine the heater was broken i fitted a new heater tested ok.
    later on that day the customer phoned complaining of a loud noise, i called out today and it is making a loud vibration noise coming from the area of the motor, i tightened up every bolt and screw i could see but no joy.
    the drum runs on pads at the front not the dreaded wheels and it is not rubbung on the backplate.
    the drum shaft does not have the usual square bush but has an eliptical bush.
    i am at a loss, it is just over a year old and it sounds terrible, worse when it reverses.
    any help greatly appreciated.
    #233219
    Re: noisy is70c indesit condenser dryer
    would suggest its the fan on the front end of the motor. so flimsy its hard to believe they could make it that way.
    #233220
    suedehead1
    thanks i had a look at it to check for broken blades it is really flimsy, i think i may change both fans just to be sure, thanks.
    #233221
    yep I did one today, the fan was not broken but it was loose on the shaft and there was evidence of it hitting the fan housing. New fan cured the noise.
    #233222
    grendel
    Yeah the front fans on these go elliptical abit in shape and make a hell of a noise also I’ve had a few where the rear fan comes loose as well when replacing these its important to get the clip on the right way….I’ll try to explain…if you get the split/cut in the fan spindle at 12 and 6 o’clock put the clip on so that it excerts its presure at 3 and 9 o’clock…Hope you understand what I mean ❗ ❗
    #233223
    suedehead1
    thanks very much i understand fully.
    #233224
    HotDog
    There is a fault with rear fixing clip not holding fan tight new clip has been modified to cure problem
    #233225
    HotDog
    There is a new fixing clip to stop rear fan coming loose ,a bit stonger than existing fixing,,
    #233226
    suedehead1
    thanks.
