noisy machine
  • #84218
    marpau77
    I have a noisy machine Siemens E-Nr. WXL167AGB/16 FD 8608 it is great but has become very noisy. I wanted to upload movie file so you could see and hear it but alas you can’t 🙁
    #425087
    noisy machine
    Drum bearings shot the most likely cause of noise. Is it noisey when you spin the empty drum?
    #425088
    marpau77
    Re: noisy machine
    no I don’t think it is that is more electro mechanical can i send you the video clip?
    #425089
    Re: noisy machine
    You should upload your video to any one of the many file sharing web sites then post a link. 😉
    #425090
    marpau77
    Re: noisy machine
    The bearings on the drum seem fine when on spin cycle empty but the pulsing electro mechanical noise come in, might it be related to the pump?
    #425091
    Re: noisy machine
    Have removed the pump filter to check for obstructions ?
    #425092
    Andy jones
    Re: noisy machine
    Select pump only. Does it still make the noise ?
