Noisy water pump
  • #97558
    frugal
    Hi All,
    I have a very noisy water pump on my Beko tumble dryer. It still pumps the water out. However, it is also randomly activated throughout the cycle when there’s no water (the float hasn’t hit the switch) at which point the noise gets much worse.
    I’m keen to fix this myself. Is there anything I can do to clean it or does it require a new part, if so which one?
    Thanks in advance.
    #468383
    new part only
    frugal
    Thanks. Is it the pump that needs replacing or the switch?
    #468385
    its will be the pump making the noise which i assume is excessive. They can squeal loudly when they go
    frugal
    Yeah it’s really bad. Thanks will order one now.
    #468387
    if you let me have a model number i will try to find the part number
    frugal
    Model is a Beko DCR93161W. Have just order this one https://www.espares.co.uk/product/es1603698. Managed to get 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} voucher too.
    #468389
    https://shop.ukwhitegoods.co.uk/m306230as-compatible-tumble-dryer-water-pump
    above should fit gen part no
    2962510300
    but double check with shop if you want to order
