noisy zanussi
  • #6699
    mal
    our zanussi nexus fl 1082 when washing is making a load of noise like broken concrete (but the concretes ok) the drum when not in use is stiff to turn also on the inside of the casing there is what looks like black soot.can anyone help.thankyou. ( ser no 81100256) ( prod no 91478955301).
    #119102
    Re: noisy zanussi
    Mal,
    There are two concrete weights on your machine – one on the back and an entire circular (annular) one around the tub front. The front one can (and does break), but neither of them would affect the action of the drum. Your description of it being stiff to turn and the black spotting all point towards bearing failure.
    This is a complete sod of a job, even for a professional! The casing must be split, the tank removed and split, the inner drum removed and then the bearings and seals replaced. Up here in Yorkshire (where we work for pence!) you’d be looking at £90 plus; bear in mind that there is a 50/50 chance that the shaft will be damaged as well, so add £35 to the bill and it’s all looking a bit expensive.
    Zanussi’s tend to be decent machines – if it’s been trouble free so far, it’s probably worth doing, otherwise – move on.
    If you check in the Directories section you may find a UKW engineer in your area, failing that, stick your postcode up in here and someone will pick up on it.
    mal
    thanx for the information penguin, time to bury it i think.
    #119104
    Buy a Bosch – personal opinion, no links or ties, just a bit better.
    Luck,
    mal
    ok thanx we’ll b having a look.
