Hi folks ive got a tricity bendix DH089 dishwasher that wont fill with water, ive stripped it down and cleaned all hoses but this didnt work so I stripped it down again and found that the motor wasnt turning over i removed the motor mounted it on a bench and it still didnt turn I then removed the fan from the motor and it worked fine, the problem seems to be a rubber washer and spring witch sits between the fan and the motor, if I tighten the screw that holds the fan on the motor the motor sticks only by slackening the screw off will it turn over, the problem with this is when the motor was put back in the machine it leaks from the the fan area.
Any help would be gratefully appreciated.
