Home › Forums › General Trade Forum › Non FSD cookers in flats, update.
- This topic has 9 replies, 5 voices, and was last updated 17 years, 10 months ago by
wsts.
June 13, 2008 at 9:41 am #37366
wsts
ParticipantThe rule which allowed the fitting of non-fsd gas cookers manufactured before 1/1/08 in flats has now expired (1st June) from now on all new gas cookers fitted in flats must have fsd’s on all burners irrespective of their manufacture date……. this rule does not affect second hand cookers.
March 22, 2010 at 1:45 pm #254581don
ModeratorRe: Non FSD cookers in flats, update.
A little bird has just informed me that as from the first April this year manufacturers can no longer supply any gas cooker without a fsd. No firm date yet for retailers to sell the old ones through though.
There will no doubt be some “dumping” of manufactured stock to the likes of DAD and Portway at bargain prices so I`m led to believe.
Don
March 22, 2010 at 6:27 pm #254582gandh1
ParticipantRe: Non FSD cookers in flats, update.
wsts wrote:this rule does not affect second hand cookers.
just like every other bit of legislation it seems. the issue being that the s/h gas cookers are almost always more likely to be more dangerous than the new out of the box models.
March 22, 2010 at 6:40 pm #254583admin
KeymasterRe: Non FSD cookers in flats, update.
Just to clarify !!
just like every other bit of legislation it seems. the issue being that the s/h gas cookers are almost always more likely to be more dangerous than the new out of the box models.If you install a second hand cooker / hob /oven.. then it is classed as a NEW installation and they ARE NOT allowed to be installed into any building that has more than one household. eg masonettes,studio flats ect.
Also its now been clarifed by HSE that IF you disconnect the bayonet fitting whilst carring out a electrical repair then you must be compedent to reconnect the said gas appliance..which is gas safe registered.
Bryan
March 22, 2010 at 7:05 pm #254584Lawrence
r600a wrote:Also its now been clarifed by HSE that IF you disconnect the bayonet fitting whilst carring out a electrical repair then you must be compedent to reconnect the said gas appliance..which is gas safe registered.Bryan
Hi Bryan
can you point me in the direction of the relevant info
LawrenceMarch 22, 2010 at 7:23 pm #254585admin
Hi lawrence
tech bulletin 25 on gas safe register,the customers are allowed to disconnect for cleaning ect but anyone at WORK must be compedent.
Bryan
March 22, 2010 at 9:25 pm #254586wsts
BryanIs this new because if you read clause 8.2.1 it quite clearly states new appliances:
The requirement was never intended to ban the use of previously-used appliances and the following amendment to clause 8.2.1 clarifies that intent, i.e. the requirement now mentions ‘new’ and the new Note 4 addresses previously-used appliances. The requirement was intended to ensure that new appliances were compliant if installed from 1st January 2008.
March 22, 2010 at 9:41 pm #254587admin
this was something discussed in my latest training that ended last week,so yes it may well be a latest update as it was only last week.
BryanMarch 22, 2010 at 9:45 pm #254588wsts
r600a wrote:Hi
BryanUnless I see it in writing I will be dubious, people have been constantly getting this one wrong and saying what you did from the moment the fsd rule came in.March 22, 2010 at 11:15 pm #254589gandh1
r600a wrote:
the customers are allowed to disconnect for cleaning ect but anyone at WORK must be compedent.so thats easy. you want to work on it you just make sure the customers disconnected it before you get there because they happen to be cleaning at the time.
but seriously
im not condoning non gas safe connection, i just dont understand why if theres so many grey spots/gaps in the legislation to allow the customer to do things, then whats the point in having such legislation for engineers? I mean half the customers out there are so dozy they probably wouldnt know if it was hooked up properly or not…
