NON GENUINE BOSCH HEATERS
  • #53032
    waters
    Tried fitting a pattern heater from 2 different suppliers and they just pull out when they are tightened up .
    Fitting a genuine one instead and had no problems.
    One pattern had less rubber but had an extra thicker bit of rubber near the tightening bracket and the other had no coller but more rubber than the genuine.
    Anyone else had problems or is it just me.I normally just fit the genuine and never had a problem
    #314143
    Re: NON GENUINE BOSCH HEATERS
    HERE.
    NOT HERE.*
    *Duff link left for fiendish moderator purposes……
    #314144
    waters
    Thanks,the Connect element just pops out and the Qualtex element is just as bad.
    The Qualtex does have a flange but its alot larger than the original and there is less seal length than the original.What a waist of money ,i got the Qualtex one last week so i orderd the Connect element thinking that might be better.
    #314145
    What is that part number of the Qualtex element and what model machine are you trying to fit it to? Since that thread I started (and Chris kindly linked to) I personally have had no problems with Qualtex pattern w/m elements.
    #314146
    spanner51
    Martin wrote: Go on Connect and the genuine is £37 + VAT or the pattern (so called) equivalent ELE9044 is only £18 +VAT
    Written on 31st March 2007
    Amazingley ELE9044 is now only £10.67 + VAT, but the genuine one, 265961, is
    £50.17. So with such a difference in the price, it is even more tempting to fit the pattern one.
    #314147
    waters
    £9.54 to me but piece of junk
