Home › Forums › General Trade Forum › nor-cool cu 200 fridge cooling unit
- This topic has 7 replies, 3 voices, and was last updated 16 years, 11 months ago by
funkyboogy.
May 2, 2009 at 7:25 am #45402
funkyboogy
Participantbeen to a customer has has a custom built fridge, basicaly a big cupboard with this nor-cool unit sitting on roof blowing cool air into cupboard, cooling unit is faulty beyond repair(model cu200), does any one know where to get a replacement, customer has been on to nor-cool and they have said dont do the cu 200 any more, they only do spit units ie one part on out side of the house..
any info would be great,
cheers allyMay 2, 2009 at 10:06 am #285578expertcat
Participantonly norcool as they were not the best units around as when i worked for expert we used to get recall after recall and norcool new of these problem with this unit.
May 2, 2009 at 10:49 am #285579funkyboogy
ParticipantRe: nor-cool cu 200 fridge cooling unit
any idea if we could drop something else in with same dimensions, as replacing whole fridge/cupboard would be really expensive
cheers allyMay 2, 2009 at 1:05 pm #285580expertcat
ParticipantWhat is the fault with the unit.
May 7, 2009 at 11:52 am #285581funkyboogy
sorry for late reply, its been regassed about 5 times had anew compressor, cond fan also faulty….
basically its just had it… customer wants to put something in thats quietercheers ally
May 7, 2009 at 12:41 pm #285582spimps
funkyboogy wrote:sorry for late reply, its been regassed about 5 times had anew compressor, cond fan also faulty….
Why not try somebody like Hawco or SRW if you give them the condenser duty/size they will match up a replacement condenser unit,stick the numbers on here and I’ll check itbout for you if you wish.
Could you extend the pipes and cables and fit an outdoor unit? woud be quiet then.
BGMay 7, 2009 at 4:25 pm #285583funkyboogy
CHEER SIMPS ..
cust no want an outside unit ??
will get a hold of specifications and let you knowthanks ally
May 8, 2009 at 5:43 pm #285584spimps
Tell them it will save on running costs outside,much better for the enviorment and all that bull 🙂
