Not completing washing cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Not completing washing cycle
  • #72154
    littleshaun
    AEG Electrolux model L50518 Pro No 914524014 01 this machine stopped spinnig at the end of program and now it is stopping at the end of the wash. I can get the machine to spin on the spin program but the rince programe as stopped working. As I have not yet taken the front of to look to see if the programe is built into the board or is the program a seperate modual that fits onto the board. any advice would be most welcome before I start. I am a lectronics engineer but from a differant field.
    #383646
    Re: Not completing washing cycle
    Check first the drain filter, then the drain pump. 😉
    #383647
    Don’tcallme love
    This may not help but I have an old AEG Oko Lavamat which had a problem some years ago: it stopped before the final spin. It has a dial which you turn to select the wash and it turned out that this was sticking. A very simple problem to solve. Discovered this after I’d called in an engineer who told me the machine needed replacing.
