Not frost free candy
  • #10770
    Kenny
    I have a candy CCFF29/13
    Evaporator behind false wall constantly blocking up with ice.
    What is the most common fault to cause this?
    This one is driving me nuts…..
    #141832
    Dave_Conway
    Re: Not frost free candy
    Moved to the trade area Kenny 😀
    Can you check the model again, I can’t find it listed by GIAS for some reason .
    There are a few near but none are frost free 😕
    #141833
    Kenny
    I managed to get a pict of the plate.. This help id the unit?
    Im not to hot on fridge freezers 😳
    #141834
    Dave_Conway
    Hmm, GIAS seem to list that product code as CCNF29/13 for some reason. No picture and only a limited number of spares listed.
    If there’s ice behind the rear wall though it’s not defrosting properly.
    Check the defrost heater and thermostats for continuity but the most common problem is the PCB on these, about £50 tarde.
    #141835
    Kenny
    Thanks Dave
    will check that out and let you know how I get on.
    #141836
    stu123
    most defo pcb but could also be low on gas being its 134a use guages to find out if below vac etc 8)
    #141837
    Kenny
    I dont think its the gas.
    Single compressor, Refigerator compartment going down to temp, and evaporator icing up.
