Not heating – siemens se24207
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Not heating – siemens se24207
  • #98893
    springchicken
    A very old and hard-working dishwasher. Everything still working, except there is no heat in the system anymore, so the contents do not dry.
    I’ve read the sticky post about heat-pump/motor combination units. Does anyone know if this is a combo or, being quite old, maybe it pre-dates that and the element is a separate and simpler repair. Or is there any other possible explanation I can explore?
    #474206
    will need the Enr number complete (example SMU25AS00E/44)
    ande the Fd number to look it up and date it
    springchicken
    Hi Dave, thanks for the response.
    I had that info and meant to include it, sorry:
    SE24207GB/04
    FD8111 400725
    #474208
    this unit pre dates heat pump models. these are built like tanks far superior build to modern units
    unit was built 2001 so your problem here could be brittle plastic in trying to get in and check things
    let the unit start and fill, then check how much water is in. try adding another pan full and see what happens. if the water level is too low heater wont come on
    you could check wires as they leave the bottom of the door as they can break at this point
    after that you need to be good with a meter
