not spinning
  • #29340
    fasetester
    hi guys if you go to a machine and it is not spinning after you check for blockages brushes pump ect do any of you ever short out the triac on the board to see if the motor will run and if the triac is not marked how do you know where to short it out or put it another way is it some thing that should be done i know the first problum is safety as you are dealing with a live circuit just like to hear your views thanks fasetester 🙂
    #222815
    goosegreen
    Re: not spinning
    I used to like the old Hoover, Creda and Whirlpool modules where you could link the separate live and neutral terminals, take the belt off and find out it was the module that was causing the fault. You could only run the motor for a second or so at full pelt or as I found out after running one for to long they tend to go up in smoke :oops:.
    Goose
    #222816
    Madmac
    Re: not spinning
    Oops ! bet u were popular ! Yep the old field & neutral linked with a driver trick was handy. Dont think id try the same with a triac tho,often more than one &and if u wreck the board…. 🙁
    #222817
    wilf
    Re: not spinning
    no no no no no no !
    wilf
    #222818
    goosegreen
    Re: not spinning
    Was that a No! then Wilf 😆
    Goose
    #222819
    Re: not spinning
    fasetester wrote:do any of you ever short out the triac on the board to see if the motor will run and if the triac is not marked how do you know where to short it out
    What an amazing question you ask there fase? The answer is no!
    #222820
    bobokines
    Re: not spinning
    There used to be a test procudure printed in the Hotpoint service manuals on the old 95 series machines.
    It involved shorting out the triac and using an analogue meter across the live and neutral on the plug top.
    The meter would fluctuate when the motor was turned as long as the arm and field wiring was in tact. It didn’t test the tacho and obviously won’t work on the later machines with a thermal door lock.
    Bob
