Not Spinning Ariston A1300
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Not Spinning Ariston A1300
  • #13841
    Flash646
    Brill forum
    Used info to take machine apart and take motor off to check brushes.
    They look worn but what do I know I work in an office.
    Gave them a clean and put it all back together again and still nothing.
    Is this still likely to be the cause even though I cleaned them up?
    I am sure I could fit them myself but £30 on brushes and still not working would not go down well with the wife. Anyone any ideas?
    #156919
    Dave_Conway
    Re: Not Spinning Ariston A1300
    How much brush was left protruding from the holder Flash ?
    #156920
    Flash646
    Dave,
    About 1 1/2cm’ish or 3/4′ in imperial
    #156921
    Dave_Conway
    Worn but not that worn then by the sound of it.
    Possibles are, pump, motor, module, pressure switch causing no spin.
    If you need an engineer, check the repairs@ link at the bottom of my post, I think that may be the way forward with this one 😀
    #156922
    Flash646
    Cheers Dave – will do
