NTC cable repairs
Home Forums General Trade Forum NTC cable repairs
Viewing 15 posts - 1 through 15 (of 15 total)
  • #81238
    kladave
    Now without stating the obvious (ie replace the wiring loom) does anyone have any tips on repairing the cables on these as they are so thin.
    #415876
    Re: NTC cable repairs
    the cable is only small because there is little or no current flowing. it does not matter if the cable you use to repair it is twice the size
    lee8
    Oh dear. :rolls:
    #415878
    electrofix wrote:It does not matter if the cable you use to repair it is twice the size
    Really?
    #415879
    Lawrence
    kladave wrote:Now without stating the obvious (ie replace the wiring loom) does anyone have any tips on repairing the cables on these as they are so thin.
    Fisher &Paykel used to do some really thin butt connectors that you then put heat shrink over,John mac or Jonah may know a part no
    #415880
    When you see a BT or NTL van stop and offer some silver across his palm and ask for some silocone bomb (crimps). Their water proof and will cure most of the low voltage wire jointing problems 🙂
    Bryan
    #415881
    I think Kladave may be referring more toward the later RAST type fitting NTC’s.
    #415882
    A1engineer
    as a ntc has a pretty precise resistance, using thicker cable would give a false resistance thus sending the wrong signal to the pcb, i don’t use butt connectors at all in these instances joining the wires with a little solder and heat shrink usually does the trick, i have seen many machines with the wires simply twisted together and taped up which doesn’t appear to have ant adverse affect.
    #415883
    philfish
    Didn’t liebherr or miele used to have a repair kit? Connectors,heat shrink etc
    Phil
    #415884
    timdowning
    I can’t see why a thicker cable would cause any problems. Perhaps lee8 & martin could explain their concerns?
    #415885
    philfish
    Hope I don’t offend or teach a granny how to suck eggs.
    Because the pcb measures resistance (that’s why you measure the resistance of both ntc and ptc not just bell them out, hence why the cable size is so small, so there is less resistance) so altering the cable size does matter because it alters the resistance which in turn gives the pcb the wrong resistance reading so the temperature will not be correct.
    Ntc= negative thermo coefficient so the resistance reading should go down
    Ptc= positive thermo coefficient so the reading goes up
    Phil
    #415886
    philfish wrote:hence why the cable size is so small, so there is less resistance) so altering the cable size does matter
    No Phil, the thinner the wire the greater the resistance.
    The issue here is patching up the broken wires and more and more NTC’s have thin ribbon cable with RAST type connector plugs. OK when the NTC has spade terminals as you can simply crimp on a couple of insulated spades. But not possible with the tiny pins used (see the photo I posted earlier) and I think that is Kladave’s problem..??
    #415887
    stratfordgirl
    The thickness of the wire is certainly not an issue. With typical ntc resistance of 10-100 kOhm, and cable resistance well under 1 Ohm, the type of wire used will have no practical effect of temperature measurement.
    The issue of connectors is broader than ntcs, and applies also to some inlet valves and many pcb edge connector. I guess these connectors are available, together with the correct assembly tools, if anyone knows of a supplier?
    #415888
    kladave
    Martin wrote:I think Kladave may be referring more toward the later RAST type fitting NTC’s.
    Sorry for the late reply but Martin is bang on,and suppose it’s just not NTC’s that have the connector either.
    I will stop a BT guy next time,thanks Bryan.
    #415889
    clayside
    Got round it so far by cutting them out of scrap machines and saving, then soldering them and heat shrinking to machine loom.
    Miele list plug part no 5514240 £2.13 ex vat, no fitting tool!
    Will order a plug and see.
    Clayside
