NTC – what is it and what does it do?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NTC – what is it and what does it do?
  • #22399
    MickGeorge
    Hi folks
    Going to show my ingnorance here but you know what they say if you don’t ask then you don’t find out..
    Noticed in a lot of fault codes and posts reference to a NTC and not sure what it means.. worked out thar pcb is printed circuit board but NTC has me baffled.. 😳
    #194806
    gegsy
    Re: NTC – what is it and what does it do?
    Hi Mick
    Have a look here http://www.designinfo.com/cornerstone/ref/negtemp.html 😉
    MickGeorge
    Thanks gregsy
    Quite a comprehensive article.. but basicaly a thermister that works negativly… presumably these are fitted to the tub or whatever like the ordenary themister and not part of the electronic board.
    Mick
    #194808
    gegsy
    MickGeorge wrote:… like the ordenary themister and not part of the electronic board.
    There are only two types of Thermister, namely negatve and positive.
    1/ A Positive Temperature Coefficient (PTC) resistor is a resistor with a positive temperature coefficient. When the temperature rises the resistance of the PTC increases.
    2/ A Negative Temperature Coefficient (NTC) resistor is also a temperature-dependent resistor, but with a negative temperature coefficient. When the temperature rises the resistance of the NTC drops.
    HTH
    MickGeorge wrote:Thanks gregsy
    Mick
    The NTC is the ‘ordinary thermistor’ attached to the drum or more often these days slotted into the heater itself on washing machines.
    Jim
    #194810
    EFS
    Look out for the temp sensor on Whirlpool ovens.
    Described as NTC but if you test it it is PTC which may confuse diagnosis 😉
    Steve
    #194811
    In this trade, NTC seems to be the universal term for any electronic temp sensing device whatever its operational function., these days.
    #194812
    eastlmark wrote:universal term for any electronic temp sensing device
    They were called thermistors when I started………
    funkyboogy
    does sound a bit more swav and sophisticated when you mention..
    yes luv your main thermister is defo in a negative co-eficient situation and need replaced….that will be lots of money please…
    as oppossed to..ehhhh yes luv its your thermostat, oh is that all…
    errr yeh…
    ps did they design them because it can talk to a digital board better than the old thermostst ????
    ally
    #194814
    funkyboogy wrote:ps did they design them because it can talk to a digital board better than the old thermostst ????
    A thermostat has just one pre- set cut-off point whereas a thermistor’s (NTC) temperature coefficient (resistance) can provide a digital electronic control system dozens of temps from the same device!
    #194815
    Jackal
    You guys need to get out more. 😀 😀 😀
    Jackal
    #194816
    gegsy
    Sssshhh…… the master doesn’t let us out 😥 😆
    #194817
    Jackal wrote:You guys need to get out more.
    :rotl:
    But it’s cold out there! (….or maybe my NTC is giving a false reading?) :hmm:
    #194818
    andy2
    Yep. The voltage value derived from the resistance is converted to an equivalent binary value in an analogue to digital converter on the microcontroller chip. This value can then be compared against a binary constant which is representative of the required temperature until the two values are approx equal.
    The same technique is used on some program selector switches eg. GIAS
    Each position of the switch selects various combinations of tiny on chip resistors which returns a unique value from which after A to D conversion the switch position can be determined by the microprocessor.
    Andy 😀
    #194819
    Gawd Andy………
    What happened to the fixed value resistance comparator array? When the the thermistor value matched the fixed selected resistance value, off it went. I could get my head round that one.
