Numatic Henry HVR 200A
  • #95242
    poshjock
    The motor is not running, I have tested power through the switch and up to the PCB.
    #459771
    you say you have checked power but are you sure you have a neutral as well .
    Have you check continuity with a meter of both live and neutral ?
    if that’s ok then its either pcb failure or motor
    poshjock
    Hi Dave
    Thanks for your reply. Yes I have checked continuity on live and neutral. I have asked the shop for details of the pcb.
