Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Ocean APM6823 Fridge freezer problem
- This topic has 7 replies, 3 voices, and was last updated 18 years, 7 months ago by
Andyb83.
September 3, 2007 at 7:39 pm #30258
Andyb83
ParticipantHi everyone!
Brand new to the forum and just hoping i can get some advice on my problem. My intergrated fridge freezers freezer compartment isnt freezing anything and is just cool. I am hoping it is just something simple i am missing!
Any help would be appreciated! 😀
September 3, 2007 at 8:59 pm #226526Andyb83
ParticipantRe: Ocean APM6823 Fridge freezer problem
An update. The bottom section of my fridge is red hot on the back wall and i am getting slightly worried! Hope its nothing to serious 🙁
September 3, 2007 at 10:03 pm #226527kwatt
KeymasterRe: Ocean APM6823 Fridge freezer problem
Is it inside the cavity that it’s warm a the lower rear?
September 3, 2007 at 10:12 pm #226528Andyb83
I think it is inside the cavity as i can only check from the inside as it is intergrated. i checked a bit ago and it seems to have cooled down slightly but it is still warm.
September 3, 2007 at 10:16 pm #226529kwatt
My first instinct is a lack of ventilation, overheated compressor running weak as it’s classic symptoms of it.
How old is the machine?
Is there a vent in the plinth or are you aware of any ventilation at the back of the units?
It is far from uncommon for kitchen fitters to assume that fridges don’t need any ventilation and they box them in, they overheat and eventually burn out. It can take a few years of being over-worked for this to happen. It’s not good news I’m afraid if this is the case.
HTH
September 3, 2007 at 11:35 pm #226530Andyb83
Thanks for the help. Think my best bet is to get an engineer out so they can have a proper look at it as i have only recently moved into the house and only know a a small amount about the appliances. Think they are about three years old and they were fitted by mfi so that would fit in with your kitchen fitters not thinking theory 😥
September 3, 2007 at 11:40 pm #226531kwatt
Hi Andy,
Sadly most kitchen fitters seem not to think or be able to read installation instructions. The single biggest problem that we get in the first few months of ownership is mis-installation but with refrigeration it often takes a while to manifest itself. 🙁
Try the repairs@ link for an engineer as they’ll be able to confirm it for you,
September 9, 2007 at 7:05 am #226532fridgeman999
i think your fridge freezer might just be iced up in the freezer section, is there ice on the back of the fridge? if so, remove baskets in the freezer and look for ice in the lower rear vents. If you see ice defrost it for at least 24 hours, with freezer door open.
The fridge is warm as i think you have switched the heater on ( orange light at top of fridge)? I so switch it off as it will not help. 😕 -
