I moved house recently and inherited an Ocean APM6823 Intergrated fridsge/freezer combination. I do not have any literature on this appliance and would be grateful if yoiu could advise me on the fridge thermostat combination. Is it lower figures 3, 2, 1 for a cooler fridge or the other way around top number down.
It is a higher number for a cooler temperature The higher number means a higher setting which means a colder setting. The numbers are only a ruler. A thermometer in each compartment will allow you to adjust precisely. All controls at the central number would usually be the normal position
