Ocean fridge/freezer APM 6825 Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Ocean fridge/freezer APM 6825 This topic has 3 replies, 4 voices, and was last updated 21 years, 3 months ago by admin. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts December 23, 2004 at 9:06 am #7205 adminKeymaster My fridge/freezer has developed the following fault: Both fridge and freezer ar no longer chilling. Power is on, light in fridge on, but compressor/motor not operating. Can anyone guide me in the right direction as to the probable cause? December 23, 2004 at 9:17 am #121978 kwattKeymaster Willie, Could be a stat fault, relay/TOC or a compressor fault. Best getting an engineer in if you’re not sure. K. December 23, 2004 at 4:45 pm #121979 clivejamesonParticipant Re: Ocean fridge/freezer APM 6825 Hi Willie kwatt is correct though depending on the model it may just be the stat which is worth replacing. This would obviously depend on the make/model of your fridge. Perhaps if you post the details here then a guide price for replacing it could be found… Clive December 23, 2004 at 5:00 pm #121980 Dave_ConwayParticipant Re: Ocean fridge/freezer APM 6825 Willie did post the make and model Clive 😉 It’s a Brandt made unit for MFI, although why it’s badged Ocean I have no idea. This one is controlled by a pcb which is the most likely failure on these, £100.39 + VAT though for the part :eeek: It may not be that of course, best call an engineer to make a diagnosis for you really Willie. Dave. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
