Ocean frost free fridge freezer, frost free not working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Ocean frost free fridge freezer, frost free not working
  • #8420
    bill_dodsworth
    We have an Ocean Frost Free Fridge Freezer (FFC 61/48) which about two months ago started making alot of noise (fan vibration I think). Since then it has started producing alot of ice, which eventually melts, leaks out of the doors leaving us with puddles. I suspect the doors haven’t been closing properly due to ice build up which has made the problem worse.
    Having read some of your posts I guess the ‘ice free’/condensor fan has packed up, but would like to know more before I go further.
    Any simple ideas for cures, or can you recommend a service engineer in the Staines, Chertsey or Egham area.
    #128566
    clyde
    Re: Ocean frost free fridge freezer, frost free not working
    bill_dodsworth wrote:about two months ago started making alot of noise (fan vibration I think). Since then it has started producing alot of ice, w
    sounds like your your freezer isn’t defrosting properly. the noises will probly be ice catching the fan blade. local engineers can be found using directories or repairs@
    or you can try totally defrosting your freezer (switch off and unplug for 36 hours with the door open) but the fault may return!
    clyde 8)
