I went to a Bosch WFF2000GB/01 yesterday, complaint: Not spinning!
As it was 10 years old I went straight for the motor, but it was perfect, no faults. Checked the pump…faultless! Plugged machine back in, switched on and it will only fill and empty 🙁
Took me ages to figure it out (and to cut a long story short :wink:) it turned out to be the neutral cable connector in the WALL SOCKET not screwed in onto the copper wire. Therefore 240 volts was showing up on test but as soon as more current was required it just stuck on spin only pumping away but the motor relay on the module would not kick in!!!
