Re: Odd smell around fridge freezer
Pour about 30ml of Miltons baby fluid down the drip channel at the back of the fridge as the majority of smells is due to debris going down this and then it evaporates and then produces smells. Unless you can pull the fridge freezer out and you should see a plastic tray on top of the compressor ( big black metal thing ) this might have water in it. If it does then wipe it out and put some of the milton fluid into it and leave it there and put the fridge freezer back.
Bryan
