Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Oh no! Another electronic nightmare. AEG La72630 EWM2000 pcb
- This topic has 19 replies, 4 voices, and was last updated 14 years, 8 months ago by
leavemetogetonwithit.
July 15, 2011 at 5:54 pm #63962
ParticipantProduct no. 91400209601 s/n 04738487
Motor starts, gives a short burst then quits. I went straight for tacho but found no fault there. Followed motor wiring back to board and found this where the tacho wires connect, along with apparently tarnished connector pins.
Trouble is, R54 has gone o/c and, what’s worse lost its inscription 🙁 .
This is an EWM2000 board. Have an old EWM1000 but it’s too different.
Any body got an old one to hand they could look at?
Here’s a third pic to give context:
Looking at pictures again, I wonder if that was a small insect with severe depression that committed suicide there and thus caused the problem.
Mike.July 15, 2011 at 6:28 pm #355649Martin
ParticipantRe: Oh no! Another electronic nightmare. AEG La72630 EWM2000
Water damage as a result of the owner tipping it on its side?
July 15, 2011 at 6:54 pm #355650leavemetogetonwithit
Not impossible I suppose. I might ask him if he did that; he wasn’t at home when I called. There is some sign of a light coloured residue at the top of the board around the relays. Have often seen this sort of thing on perfectly functioning boards though.
Mike.July 16, 2011 at 10:37 am #355651leavemetogetonwithit
Urgent question: If I got a new board for him, would I be able to programme it from the fascia buttons or would it only be programmable by a Lux engineer?
Mike.July 16, 2011 at 2:02 pm #355652Martin
Using the buttons inserting the config code. Can give you code when I get back to my office tomorrow if you like?
July 16, 2011 at 3:13 pm #355653leavemetogetonwithit
Thanks Martin; hold off for now. Can’t get hold of customer to find out what he wants to do. Rather doubt I’ll have to go that route anyway, since machine is 10/11 years old and the board retails at £116.
Mike.July 16, 2011 at 11:42 pm #355654leavemetogetonwithit
Customer says yes without hesitation. Hmm. Not really looking forward to it. So yes please for the code, Martin.
Mike.July 17, 2011 at 10:17 am #355655Martin
leavemetogetonwithit wrote:So yes please for the code, Martin.
Mike.OK, the configuration code is printed on the module case (big red label), then read Page 32 of the pdf file. 😉
July 17, 2011 at 2:39 pm #355656leavemetogetonwithit
No big red label on the old one. Assume there will be one on the new.
Had already looked at TDS disc and could not figure out how to access the pdf entitled service manual and none present on Connect for this model. 😕
Mike.
Edit: OK I got the manual anyway. Just had to use keyboard on Connect to scroll down and reveal previously invisible options. Looks like a worse nightmare than trying to repair the old one.July 18, 2011 at 6:54 am #355657admin
KeymasterRe: Oh no! Another electronic nightmare. AEG La72630 EWM2000
Assuming that it’s LAV72630 PNC:914002092_02 than config. code is: 261C169B15C1C7A4 (you can check it by putting the old board and go into service mode at configuration stage and check bit by bit…).
In order to repair the old board you need: R54(123)=12K; R53(330)=33 Ohms; R52(473)=47K; D15= 1N4148; Q7(5Cp)=BC807/40. But also you have to remove all relays from the board and do an clean/wash with alcohol and afterwards to check tacho generator from motor for its condition…
July 18, 2011 at 12:54 pm #355658leavemetogetonwithit
Baron, you are brilliant! I’ll go straight ahead and order the components and leave the new module/configuration lark as a last resort. I did suspect R53 (reading open) and the others and was going to test them. Also I see the big relay with the clear plastic cover looks quite blackened which is only to be expected given age of machine. Might as well replace all relays if I’m going to remove them and make a proper job of it.
Will update when all done. Many thanks to you 😀 .
Mike.July 19, 2011 at 7:56 am #355659admin
Welcome Mike, :waving:
Isn’t necessary to change all relays at all 🙂 … just the transparent one you have to remove it from PCB, open and clean his contacts with glass-paper! it is the ‘Heater Relay’ and therefore is a bit dirty :snigger: !!!July 19, 2011 at 8:09 am #355660admin
P.S.
baron wrote:Assuming that it’s LAV72630 PNC:914002092_02 than config. code is: 261C169B15C1C7A4 (you can check it by putting the old board and go into service mode at configuration stage and check bit by bit…).
I looked again and checked the configuration code for your PNC (because I didn’t saw 😳 that you wrote it…) but it is identical
…July 19, 2011 at 10:06 am #355661leavemetogetonwithit
baron wrote:
open and clean his contacts with glass-paper!Ha ha. You Romanians are even more penny-pinching than us Brits 😆 . I suppose it’s a question of necessity 🙁 .
Anyway, the 33 ohm smd resistors were expensive for some reason so I ordered a normal axial one (same spec) which there is room for. And I’m going to remove a diode from an old board as the new ones looked different and were also a bit pricey as you have to buy 100.
Hopefully won’t need that config code this time round.
Mike.July 19, 2011 at 3:50 pm #355662admin
leavemetogetonwithit wrote:Anyway, the 33 ohm smd resistors were expensive for some reason so I ordered a normal axial one (same spec) which there is room for.
Mike.Put there any smd resistor around that value… for ex.: 22 or 47 or 56 … it does not matter because is just for current protection…
leavemetogetonwithit wrote:Ha ha. You Romanians are even more penny-pinching than us Brits 😆 . I suppose it’s a question of necessity 🙁 .
Mike.Is not all the time about money… but it’s much quicker and cheaper so I don’t want to enlarge my store with all kind of unnecessary components (in my repairman live I did not changed more than three pieces of those relays but sealed type a lot)…
