Oh no! Another electronic nightmare. AEG La72630 EWM2000 pcb
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Oh no! Another electronic nightmare. AEG La72630 EWM2000 pcb
Viewing 5 posts - 16 through 20 (of 20 total)
  • #355663
    Allsorts
    Re: Oh no! Another electronic nightmare. AEG La72630 EWM2000
    baron wrote:In order to repair the old board you need: R54(123)=12K; R53(330)=33 Ohms; R52(473)=47K
    Not being picky here, just wanting to pick-up some learning…. since 123=12K and 473=47K, why is it that 330=33 Ohms and not 33K?
    George
    #355664
    like the others:
    123= 12×1000 (10 at power to 3) Ohms = 12K
    473= 47×1000 (10 at power to 3) Ohms = 47K
    so
    330= 33×1 (10 at power to 0) Ohms = 33 Ohms
    In other words SMD resistor codes could be found:
    http://www.hobby-hour.com/electronics/smdcalc.php
    #355665
    Allsorts
    Understood.
    Very handy link.
    George
    #355666
    So…
    This is what it looked like after I removed the relays. So Martin was right about water getting in, I think.
    And this is what it looked like after I cleaned it up and soldered in the new components (used a wire-in diode and s/h 33R and 47kR because I ordered wrong ones 😳 ).
    Thinking to myself, “What if it all goes pear-shaped?” I took Baron’s advice and only cleaned the big relay. The others I opened up and checked they were OK, then re-installed them.
    And not forgetting to clean up the cremation site. As you can see, there had been quite a burn up there.
    Then this morning I tentatively put it all back in the machine, switched on and waited for the BANG.
    To my relief, it just acted as though nothing had ever been wrong. :wobble:
    Customer not present, so have left instructions to monitor machine during first couple of uses but have high hopes that I won’t get a re-call. If It bounces I’ll blame Baron 😆 . How much is a pint in Romania, BTW?
    Mike.
    #355667
    :wave:
    I’m amazed about your work…well done… but could you used any smd diode from all any other boards which are connected on relays coil…
    A pint of :beer: is very gooood :bounce: …
