Re: Oko Lavamat 6100
Element failure is a good bet at this age – possibly caused by problems with the water level control system becoming sludged. Burnt/broken wiring is another possibility, the thermostat and the timer control system itself may be causing problems. Technically, this is a complex (although excellent quality) appliance, well worth having investigated.
If you’re not sure how to investigate the possibilities, please click the repairs@ link for an engineer in your area. If you are going to proceed, please ensure that the plug is pulled at all times.
