old belling door hinges
  • #5621
    streetlighter
    Hi all
    Does any one know why I can get belling xou188 m/o hinges from.
    part no as188/ha seem obsolete
    Thought these would be high use parts ❓
    suppose oven is old, but in exerlant order surely not scrap just for saggy hinges. 😥
    ta
    paul
    #112233
    Dave_Conway
    Re: old belling door hinges
    Is that the swinging door or the drop down door ?
    streetlighter
    Hi dave
    Its the drop down door
    I can get the guides but it makes no differance when these are changed.
    All the pins are in place on hinges but the door still drops to far and wont hold closed.
    paul
    #112235
    Dave_Conway
    It’s your lucky day then cos I’ve got a pair 😀
    Yours for a tenner for the pair and postage if you want them.
    #112236
    hi,
    just a thought you should check the door frame.
    It has a slot which is shaped to allow a roller(part of the hinge ) to follow.If the slot wears the door will not “snap shut” and I think the door frame is obsolete.
    kheath
    #112237
    You need hinge socket kit part number AS632490 and follow the instructions regarding drilling alternative holes in the black square mounting blocks. (pedastal drill is best for this as you need it straight and in the right place!) This takes up the wear in the door frame (long obsolete) and works everytime for us.
    anyone out there got any old fromat swing out hinges? as these are now obsolete.
