old belling. who has these hinges for top oven
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts old belling. who has these hinges for top oven
  • #25665
    TELL
    i’m after a set of top oven hinges for this old, but good condition cooker. the model is the old Belling format range 600XR2. the part no’s for the hinges are: AS805680….. i need the pair, LH/RH. connect and master parts are obselete. P.S. i need the cost of them aswell. thanks.
    TELL..
    #206945
    Dave_Conway
    Re: old belling. who has these hinges for top oven
    You sure you don’t just need the (common failure) aluminium sockets Tell ?
    BL1414 is the kit if you do from Masterpart 🙂
    The hinges themselves are deffo obsolete now 🙁
    #206946
    TELL
    thanks dave for the info, but definatley needed the hinges, have more or less told customer of parts could be obselete.
    Tell..
    #206947
    aqualectric
    If the hinges are not broken but are not pulling the door shut tight, it is possible to correct the problem.
    Strip the door and release the springs to the hinge carriage (the part with the rollers on it). With a rat- tail file, file the slot in the frame upwards about 5-6 mm on the inner and outer part of the frame keeping it the same dimension all the way. Test by pushing the hinge up to check the rollers don’t bind at any point in the slot. Repeat for the other hinge on the other side of the frame. When the springs are refitted, the hinge tangs should be leaning towards the top of the door. Refit the door to test: file slots more if required. Grease the slots and reassemble. Refit the door.
    Easy enough job to do; I did quite a few like this in the past, all worked OK. 8)
    Sometimes my aircraft engineering training comes in handy…….
    Steve.
    #206948
    TELL
    thanks steve, will give it a go.
    Tell..
