Old creda 48301 fan motor replacement ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Old creda 48301 fan motor replacement ?
  • #87624
    Cras
    Hi, is it possible to fit a normal universal Hotpoint fan motor to one of these in place of the original three terminal fan motor ,in terms of where the third cable goes .? ,everything is goosed on the old unit and most parts are obsolete,also customer doesn’t want to spend to much . Advice ,info appreciated thanks Cras
    #435447
    Re: Old creda 48301 fan motor replacement ?
    did you know electrue have the correct motor in stock
    Cras
    Yes last time I looked rear fan , internal fan and grommet were obsolete but all needed on this repair ,also even in available elsewhere ,it makes the job expensive ,was trying to help customer out by keeping cost down .
    #435449
    the mounting of this fan means most motors wont fit as the shaft is long
    most common motors these days are short shaft and the motor is bolted to the back of the oven. if you did fit one of these you would have a problem because the hole the fan shaft comes through is quite large to allow for movement so you would need to make a plate to reduce the size of this hole.
    all in all I can understand your trying to help out a customer, we all do this every day but there may be a lot of work to modify this
    Cras
    Thanks for replies ,frustrating because I can get the fan ,grommet and motor but not the internal fan blade ,customer says she wants to spend the money and keep it going ,out of interest can anybody tell me why there are three cables ? ,changed a few of these in the past but as I was changing like for like I never gave it much thought .Cras
    #435451
    because there is a toc in the motor that custs out the element if motor overheats
    so you have live in
    neutral in and out to the element
