Old Electrolux ew1200i timer removal
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Old Electrolux ew1200i timer removal
  • #102640
    washingmachinewoman
    I’m attempting to change a timer on an Electrolux ew1200i, pnc 914674010/01
    Can’t work out how to get the timer off. The replacement timer has a thread at the end of the shaft, which makes me think something unscrew, but nothing is budging and as the buttons are no longer available, I don’t want to break anything.
    Any ideas?
    #489792
    washingmachinewoman
    Just ignore me. Found it!
    To save anybody else’s embarrassment, take out the blue rubber from around the knob, remove the knob cap, and you’ll get access to the shaft. 7mm nut.
    #489793
    common fault on these older timers is the capacitor on the board providing the power to the electronics
    if it goes machine wont move on or reach full spin speed
    washingmachinewoman
    Wasn’t that this time. When on/off switch was pressed it tripped the electrics. Then the button would not keep down, although light came on, and the machine would just sit there doing nothing.
    On inspection, a track was blown on timer and the on/off switch also needed replacing.
    It was a heck of a fiddly job, with the two screws holding the timer to the frame seized. The top one was especially tricky as the head was damaged. Not to mention all the brittle plastic everywhere. It nearly defeated me, that one.
    #489795
    really satisfying when you crack an akward one
