old electrolux freezer / ranco stat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries old electrolux freezer / ranco stat
  • #18966
    keithwilliams
    been to an old lux freezer with a ranco stat with a very short coiled capillary. terminals are numbered 1 2 3.
    the replacement is a ranco k54 p3101 with the usual numbers 6 4 3.
    can you tell me how this relates to 1 2 3? please.
    i suspect that 1 is live and 2 is motor is that right
    wiring on freezer is brown which was 1
    black which was 2
    white which was 3
    thanks
    #181115
    Dave_Conway
    Re: old electrolux freezer / ranco stat
    6 = live
    4 = compressor
    3 = light or other switch off at zero
    #181116
    keithwilliams
    thanks dave,
    i didn,t make myself clear enough. i know how to wire a new stat. the problem is that there are all sorts of wires etc in the stat compartment and i suppose i was looking for an easy way to work out which was which by identifying the 1 2 3 terminals on the old stat.
    thanks
    #181117
    Dave_Conway
    Ah, sorry 😳
    Have you got the model number ? I’ll check to see if a wiring diagram is available 🙂
    #181118
    MKR
    Dave_Conway wrote:6 = live
    4 = compressor
    On the K54’s I think you will find it’s;
    6 = All’s well light (3 on old stat)
    4 = compressor (2 on old stat)
    3 = Live (1 on old stat)
    On K59’s Dave’s got it right.
    #181119
    keithwilliams
    thanks mkr
    all now makes sense. the thing that was getting me was the fact that there was no continuity between 6 and 4 at room temperature. therefore if it was wired same as a vt9 then surely these would have been closed.
    i’ll experiment with the stat this weekend with my multimeter and cooling it in my own freezer. i’ve bought myself some time with the customer by cleaning the contacts in her old stat to at least get it running. word back is that it’s working fine so far.
    incidentally the tech guy at ranco was clueless. he even told me that the old stat was definately NOT one of theirs even when i told him it had ranco stamped all over it.
    cheers
    keith
    #181120
    MKR
    6 is the feed to the “all’s well light” on these older models (not a high temp warning light.) When the stat cools to a safe temp, the circuit will be made between 3 and 6 (and 4 until the compressor switches off.)
    keithwilliams wrote:incidentally the tech guy at ranco was clueless. he even told me that the old stat was definately NOT one of theirs even when i told him it had ranco stamped all over it.
    We are talking stats that are over 25 years old… probably before he was born 😆
