Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Old Indesit 1996 w/machine drum not turning – PCB problem???
- This topic has 8 replies, 3 voices, and was last updated 19 years, 11 months ago by
eurovettes.
April 27, 2006 at 2:00 pm #17434
eurovettes
ParticipantI have an old but stored and now in service for 1 year Indesit WN1063WG circa 1996
drum will suddenly not turn or spin – have changed w/wound resistor on control board (blown/corroded) with hopefully similar type/values – still not turning, but if pcb shroud is touched on motor (earthed??) the motor spins but is not controlled.
No other visible faults with pcb # EM13SFB – old resistor # is MO5S 5Ks 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} replacement from Maplin part# L5R6 is 7W w/w 5.6RAny ideas if there is another component to be checked – I can’t ID any other track faults on the PCB
I am not a elec techy but am competant on elec diagnostics
April 27, 2006 at 7:32 pm #174324Penguin45
ParticipantRe: Old Indesit 1996 w/machine drum not turning – PCB proble
Triac probably – Radio Spares carry a good range.
Please don’t do live testing, very dangerous.
Penguin45.April 28, 2006 at 4:43 pm #174325eurovettes
forgive my ignorance but whats a TRIAC and does it need programming or simply replacing – how do I tell numbers etc
April 28, 2006 at 6:20 pm #174326Penguin45
Three leggedy beasty secured to the heatsink.
April 28, 2006 at 7:47 pm #174327eurovettes
code on this beasty is
MAC15 A10 9535 with a small Motorola logo wing on itI have digi pics of this damn board and Triac cnat attatch them to this post – bolts to the large matal shroud – I assume this is the heat shrink no other 3 legged things lurking that Ican see – oh there is a small blue square thing in the PCB with a white centre and 47K on the top- not bolted to anything
I really appreciate your help and patience
cheers keithApril 28, 2006 at 11:36 pm #174328Penguin45
This should be a suitable alternative:
http://rswww.com/cgi-bin/bv/rswww/subRa … cheID=ukieHTH,
Penguin45.April 29, 2006 at 8:24 am #174329eurovettes
try as I may – this link will not connect to page
April 29, 2006 at 9:39 am #174330don
ModeratorRe: Old Indesit 1996 w/machine drum not turning – PCB proble
Hi eurovettes
Link seems to be working okay now. Try this one if you are still having problems http://rswww.com/cgi-bin/bv/rswww/home.do?cacheID=ukie
HTH
Don
May 8, 2006 at 11:01 am #174331eurovettes
after much searching – icant get onto the rs webpage – so Icalled up tech support – helpful – gave me aRS partno of 5450191 but not in stock till July !!!! – cant look that no up on their search page – stumped
silly q but what does a Triac do??? – would Maplin keep these do you think or ???
cheers
keith -
