Old Servis made washing machine valves
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Old Servis made washing machine valves
  • #18332
    Washman
    Any one have part numbers for the hot and cold fill valves with larger than standard outlets (dual cold 90deg / hot 90deg) Old Servis made machine no model no avalable.
    Thanks in advance
    Mike
    #178622
    Re: Old Servis made washing machine valves
    Maddocks still have the double valve 3367 listed as 71-SV-01. No listing for the single one – maybe have a word with a commercial laundry supplier?
    MickGeorge
    Think Connect still do a pattern dual cold valve part no VAL3634.. sorry havn’t got a hot valve no..
    #178624
    MickGeorge
    oops.. just re read the post and you wanted 90deg valves… the number I gave you was for ordernary straight through type… sorry 😳
    #178625
    whitevanman
    Hotpoint 95/wm series will fit,
    Cut length of cold fill pipe to fit to end of spigot (very tight fit) use debor then fit hose from dispensor over mod use jubillee clip and tighten.
    Never had one fail yet.
    Hope this helps
    Wvm
    #178626
    wilf
    if the hoses are too big clamp them down with a SMALL jubilee clip. if its the one I think you mean you should have no trouble
    wilf
    #178627
    burns
    These were done by washvac as pattern Invicata parts. they werent expensive.
    genuine part no 534006701 double / 534000301 single
